When I use the “SelName” tool to select parts by name, it gives me an incorrect number of parts. I also cannot see any pattern in the mistake, the wrong amount is at random. It does this for all parts(Polysurfaces), sometimes it adds curves which are not there. No objects are hidden or made invisible. This happens since the last update. Havea look at the pictures, starting from bottom up. I select a name and it shows me 12 Polysurfaces selected. But there really are only 6 Polysurfaces with the same name if a select them manually Anybody having the same problem?
Sure you don’t have duplicate objects grouped together somehow?
Good Morning Helvetosaur
Nope, the file has no groups.
Thanx for your quick responds.
You don´t have that problem?
So, when I use Peter’s Tools and make a BOM, I suppose it makes it from the Object’s names?, then the number of the objects are correct !
No. Can you post the file that shows the problem?
I would like to upload it but it’s 200MB and my brand new super high speed german glass fibre is as fast as thick mud in a funnel :))
Helvetosaur, I could send you a download link so you could download it from my one drive if you give me an email address
Use the Message function in Discourse… (click on my avatar)
