Bug? The control points disappear in a random fashion
The control points in the latest Rhino 9 WIP disappear in a random fashion. Their visibility is dynamic and depends on the viewing angle and the distance from the objects. Or maybe I’m using some secret feature?
The bug is only seen in OpenGL. When I switch to DirectX, there is no issue. The interesting part is that some of the display modes don’t exhibit this graphics bug, but others (including the default “Shaded” mode) fail to render the control points that are supposed to be closer to the camera than the surfaces.
Perhaps there is a secret command called _testHoudini that makes the control points disappear? :slight_smile:
Here is another video that shows the behaviour of the viewport when I switch between different display modes:
