Bug when sliding a subd edge or edge loop, after making a slide, then accepting, not able to undo that operation properly. The undo is skipping the slide and instead undoing the last command prior to the slide and then redo puts the subd back to where it was prior to the slide.
Isn’t happening all the time. Can’t figure out what’s triggering it.
This is for Work In Progress
(7.0.19295.11595, 10/22/2019)
I had this problem with slide edge in a previous WIP, when I slid the edge to the furthest extreme possible. It only happened at the furthest extremes and it happened exactly as he’s describing it. Not happening in the current version.
