BUG: Selecting font with more than two words doesn't work
(Rheinason) #1
We have a font called URW DIN that we use for most of our drawing material, the problem is that we can only select versions of the font with two or less words in the title. So for example: URW DIN Black becomes just URW DIN. Verdana Pro Cond Black becomes Verdana Pro.
(Francesc Salla) #2
Hi Roi, I guess you mean this happens when text is used by some VisualARQ object, (like a “Tag”), right?
We will review this and get back to you.
(Rheinason) #3
Just found a bug that I’m decently certain is Rhino related that might be related to this issue: BUG: Font changes when selecting text
(Francesc Salla) #4
Thanks for the note.
(Rheinason) #5
Hi Francesc, is there any news on this case? It’s really frustrating and creating a workflow where we have to explode the Spaces to get the font that we want to use.
(Francesc Salla) #6
Hi Roi,
This issue is Rhino related. I think it is fixed in the SR14. You can follow it up here: https://mcneel.myjetbrains.com/youtrack/issue/RH-50733
(Wim Dekeyser) #7
The issue is fixed, yes, and the release target is SR13.
The final SR13 should be right around the corner - unless some last-minute thing has prevented that from happening…
