… when opening the same file via menu File > Open, it does not crash.
Just installed 6.0.17066.12281, same as before.
Error log sent.
Thanks!
Best regards
Eugen
Error log sent.
Thanks!
Best regards
Eugen
Hi Eugen - can you repeat this with any file that shows on that splash?
Hello!
No, in fact it seems to be ok now for all files in the latest WIP, 6.0.17066.12281, 07.03.2017.
You fixed a lot in that one, didn’t you. =]
Thanks!!
Best regards
Eugen
Hi!
Unfortunately, I was wrong - Rhino WIP still crashes when opening a project from the startup screen.
It happened with 2 different projects already, so it might not be project-related.
I sent the crash report plus file a moment ago.
Best regards
Eugen
H Eugen - thanks for sending the crash dump - if you can determine if it is specific to a file, can you then also try opening the same file from the FIle menu or just by navigating to the file with Open? Any different?
Hello!
I just tried 3 different files. Opening them from the file menu works fine, but the same ones opened from the splash screen leads to a crash.
Best regards
Eugen
Hi Eugen - is this still a problem in the latest WIP build?
Hello!
No it isn’t! Looks like you fixed this, thanks!!
Best regards
Eugen
