My Rhino document has units set to millimeters, yet block position seems to be in inches. Also Rotations has inches as the units, and the block scaling also says inches. Last time I checked, scaling factors are ratios and unitless. How did I screw this up?
So is this a bug? Is this intentional? If it is a bug, do we have a ticket we can track and an estimated timeline to fixing this?
Hi @cameronbehning,
Block definitions do have units.
You might consider posting your file(s).
– Dale
Hmm, I can’t seem to reproduce the problem which is both convenient and frustrating because this isn’t the first time I’ve had this issues. I will post a file and instruction to reproduce once I figure that out.
