Bug Rh9 Raytraced ignores "By Parent" material, uses layer instead
AM57-58
AM 24 06 57-58 2 Rh9 RaytracedMaterial.3dm (3.0 MB)
While creating this glider vario, I discovered several issues that I’ve isolated in the attached Rhino file. I believe there are two related bugs in Rh9 WIP (9.0.25343.14055, 2025-12-09) with material assignment inconsistencies between Raytraced and Rendered viewports.
Bug 1: Inconsistency between Raytraced and Rendered viewports.
A polysurface shows different materials in Raytraced (uses layer material) versus Rendered (shows manually assigned materials correctly).
Bug 2: Raytraced ignores “By Parent” material assignment.
Object Properties set to Material > By Parent, but Raytraced uses layer material instead. This suggests a missing integration between object-assigned materials and Properties settings.
Video demonstration for Rhino Team: https://youtu.be/bAi0ry0SLV0
Thanks for investigating.
Hi Alan, Thanks for reporting and providing the example.
RH-91045 Inconsistency between Raytraced and Rendered viewports
RH-91046 Raytraced ignores “By Parent” material assignment.
not sure if the latter is a bug. AFAIK by parent is only for block instances. Here’s an example what happens:
materials-blockinstances.3dm (3.1 MB)
