Bug: Project Loose Changes Crv Structure
Project Loose is altering the structure of the output curves. Here are 4 examples (file: projectLooseBug.3dm):
1) The projection of a polycrv with two segments (deg3/8 and deg1/2) is exploded and deg 1/2 curve is rebuilt to deg3/4.
//parent
  Geometry:
    Valid curve.
    Closed polycurve with 2 curve segments.
      Segment 1:
        Open NURBS curve
          start = (-0.580,0.275,0.000)
          end = (-0.584,1.204,0.000)
          degree = 3
          control points: non-rational, count=8
          knots: uniform (delta=1.000), domain = 1.000 to 6.000
          clamped at start and end
      Segment 2:
        Line
          start = (-0.584,1.204,0.000)
          end = (-0.580,0.275,0.000)
          domain = 6.000 to 6.929
          line length = 0.929
//children
  Geometry:
    Valid curve.
    Open NURBS curve
      start = (-0.580,0.275,8.817)
      end = (-0.584,1.204,8.814)
      degree = 3
  Geometry:
    Valid curve.
    Open NURBS curve (SubD friendly)
      start = (-0.584,1.204,8.814)
      end = (-0.580,0.275,8.817)
      degree = 3
      control points: non-rational, count=4
      knots: uniform (delta=0.929), domain = 6.000 to 6.929
2) The projection of a polycrv with two segments (deg3/8 and deg3/5) is exploded, degree and point counts are unchanged.
//parent
  Geometry:
    Valid curve.
      Segment 1:
        Open NURBS curve
          start = (1.257,1.204,0.000)
          end = (1.257,0.275,0.000)
          degree = 3
          control points: non-rational, count=5
          knots: uniform (delta=0.500), domain = 0.000 to 1.000
      Segment 2:
        Open NURBS curve
          start = (1.257,0.275,0.000)
          end = (1.257,1.204,0.000)
          degree = 3
//children
  Geometry:
    Valid curve.
    Open NURBS curve
      start = (1.257,1.204,6.382)
      end = (1.257,0.275,6.382)
      degree = 3
  Geometry:
    Valid curve.
    Open NURBS curve
      start = (1.257,0.275,6.382)
      end = (1.257,1.204,6.382)
      degree = 3
3) The projection of a polycrv with two segments (deg3/8 and deg3/5) with continuity closer to G1 than G0 results in a single non-uniform deg3/12 curve that is not smooth(?!?) and will explode into two curves(?!?).
//parent
  Geometry:
    Valid curve.
      Segment 1:
        Open NURBS curve
          start = (-0.617,-0.241,0.000)
          end = (-0.617,-1.170,0.000)
          degree = 3
      Segment 2:
        Open NURBS curve
          start = (-0.617,-1.170,0.000)
          end = (-0.617,-0.241,0.000)
          degree = 3
//child
  Geometry:
    Valid curve.
    Closed NURBS curve
      start = (-0.617,-0.241,5.064)
      end = (-0.617,-0.241,5.064)
      degree = 3
      control points: non-rational, count=12 (1 duplicate)
      knots: non-uniform, domain = 0.000 to 6.000
      Curve is not smooth.  If you explode it, it will become two or more curves.
4) The projection of a polycrv with two segments (deg3/8 and deg3/5) that are G1 results in a single deg3/12 curve that is non-uniform and non-periodic.
//parent
  Geometry:
    Valid curve.
      Segment 1:
        Open NURBS curve
          start = (1.177,-0.241,0.000)
          end = (1.177,-1.170,0.000)
          degree = 3
      Segment 2:
        Open NURBS curve
          start = (1.177,-1.170,0.000)
          end = (1.177,-0.241,0.000)
          degree = 3
//child
  Geometry:
    Valid curve.
    Closed NURBS curve
      start = (1.177,-0.241,6.326)
      end = (1.177,-0.241,6.326)
      degree = 3
I tried using a scripted function that projects curves along a vector (in this case World Z axis) to a plane. The plane was determined by picking 3 points on your surface plane. This way does not seem to alter the curve structure - just submitted as a comparison/debug help.
import scriptcontext as sc
import Rhino
def TestProjectAlong():
    crv_ids=rs.GetObjects("Select curves to project",4,preselect=True)
    if not crv_ids: return
    msg1="Pick point for origin"
    msg2="Pick point for X axis and then Y axis"
    pts=rs.GetPoints(True,message1=msg1, message2=msg2, max_points=3)
    if not pts: return
    plane=rs.PlaneFromPoints(pts[0],pts[1],pts[2])
    crvs=[rs.coercecurve(crv_id) for crv_id in crv_ids]
    proj_vec=Rhino.Geometry.Vector3d(0,0,1)
    xform=Rhino.Geometry.Transform.ProjectAlong(plane,proj_vec)
    for crv in crvs: crv.Transform(xform)
    proj_ids=[sc.doc.Objects.AddCurve(crv) for crv in crvs]
    rs.SelectObjects(proj_ids)
TestProjectAlong()
projectLooseBug-test-msh.3dm (4.0 MB)
Thanks - my guess of the moment is this may be related to the maintaining of sub curve structure within a polycurve. I’ll run it by the developer - Projecting edit points does the right thing, at least in my quick test.
RH-70679 Project > Loose changes curves
Yeah, that works but then there’s no history. I need to get profiles into place matching a particular projection angle.
That works for 3 of those 4 cases (which are the ones I care about). It does a weird thing with the first case(deg3/8 and deg1/2). It starts off perfect, but after the first edit, the line sub curve teleports from the child to the parent.
That is possible to do via scripting, but I haven’t done it often, so it may take some experimenting…
Voila, it actually wasn’t that hard.
import Rhino
import Rhino.ApplicationSettings.HistorySettings as hs
def TestProjectAlongWHist():
    hist=hs.RecordingEnabled
    if not pts: return
    proj_ids=[sc.doc.Objects.TransformWithHistory(crv_id,xform) for crv_id in crv_ids]
projectLooseBug-test-msh2.3dm (4.0 MB)
Can you make the plane be a part of history? I need it to move along the Z.
No, because it’s not an object and it’s not associated with the surface in the file. The script was just proof-of-concept that projecting to a plane can work correctly. I think the problem is that the code for Project (to a surface) is not the same as project to a theoretical plane, because you can also project to non-planar surfaces.
dear @EricM
a possible workaround:
if you just project to a plane - you can use shear instead.
_shear copy=yes
supports history.
screenshot shows how to find the correct points for shear, in your case cplane = front
Thanks, I get that, but I really need the history for the crv and the plane. I need to edit the profile crv, the projection angle, and the projection distance.
@pascal, projecting the points works for now. I tried using Joincopy as a workaround, but the output polycrv was especially prone to randomly flip the seam location and/or direction with different projection angles. I’m not sure if @mikko is aware of that issue with Joincopy.
I love Joincopy, it’s a huge time saver, I use it dozens of times per day…but I am really bummed out when a seam/dir flips and my lofts go haywire.
