I don’t know if the old meshing problem was considered to be solved, but when I added a Bongo pivot (to the end of a line serving as a rotation axis) this old acquaintance showed up again:
Thanks for reporting this. The issue isn’t actually a meshing problem. It’s the links between parents and children being drawn so densely it appears that way. This has to do with your groupings as well as how closely I draw the links together. I’ll put a fix for this in the next WIP.
For now you can disable drawing hierarchy links in the Bongo Document Properties if you find it annoying.
