works on nurbs, but on a mesh it will be broken and you cannot MeshToNURB (no error but it wont happen). whereas if you do the polysurface first you can flip back and forth between conversions fine.
trying to extrude the sides will just move that side out.
steps:
make a MeshBox (1, so not subdivided)
grab an edge and slide it down with the gumball (now we have a pretty ramp)
try extruding the side face, it will slide out
try MeshToNurb, it will not do anything and not complain
yeye it is. but the point is, if you do it in nurbs it doens’t do it(only in rhino 9 has it been added as a fix, which is great).
and other mesh/polygon editing tools it would always be fine when you merge the edges. it’s quite common when dealing with meshes that you want to slide edges together and merge them.
mesh
Object name: (not named)
Layer name: Default
Render Material:
source = from layer
index = -1
Geometry:
Invalid mesh.
Open double precision polygon mesh: 24 vertices, 6 faces with normals
Bounding box: (0.000,-5.000,0.000) to (7.000,3.000,6.000)
But this is different right? i haven’t actually enabled that option, isn’t that for 2 faces joining when you extrude something up into another thing? (so you don’t have to faces inside the model huggin each other having a good time).
Ideally this behaviour that got fixed for nurbs, would also be toggleable and not try to merge/ruin the object, but leave 2 edges alone (if you wanted it). but default behaviour to merge properly (like it does in nurbs in 9) would be very good. (in blender for example you have automatic merge by distance etc, but here just having automatic merge when they align like the nurbs one would be so good).
BUT stitching basically does the correct behaviour, so that is a great workaround in some cases thank you!
actually, for nurbs and version 8 you dont have stitch, so how would you do that without the gumball corrected behaviour?
anyway the buggy behaviour in nurbs that got fixed, would be great to also have it on meshes
edit: and appreciate you helping and using your time!!
