BUG : "Line Tangent Two Curves" not robust
Here’s a case of “Line Tangent Two Curves” playing with my nerves :
If there was a way to make it create the 4 possible lines, one could erase the un-wanted ones and move on whith his work.
This tool, along with “Line Tangent-Perpendicular”, and others are a mediocre excuse for not having proper dynamic sketch constraints in Rhino, but at least, they should be robust.
Hi Olivier -
I’m trying to reproduce that behavior here but am failing miserably. Would you be able to post those curves in a 3dm file?
from Rhino.Input.Custom import GetPoint
from Rhino.RhinoMath import Clamp
from Rhino.Commands import Result
from System.Drawing import Color
from scriptcontext import doc
import Rhino.Geometry as rg
import math
class GeGuidePoint(GetPoint):
    def __init__(self, lines):
        self.m_lines = lines
        self.line = rg.Line.Unset
    def OnDynamicDraw(self, e):
        ds = []
        for line in self.m_lines:
            ds.append(line.DistanceTo(e.CurrentPoint, True))
        self.line = self.m_lines[ds.index(min(ds))]
        e.Display.DrawLine(self.line, Color.White)
def circleGeometryFilter(rhObject, geometry, componentIndex):
    return rs.coercecurve(geometry).TryGetCircle()[0]
def SolveTangents(cir0, cir1):
    tangents = []
    num1 = cir0.Center.DistanceTo(cir1.Center)
    cir2 = rg.Circle(rg.Plane.WorldXY, cir0.Radius)
    cir3 = rg.Circle(rg.Plane.WorldXY, cir1.Radius)
    cir3.Center = rg.Point3d(num1, 0.0, 0.0)
    if cir0.Radius + cir1.Radius < num1:
        d = Clamp((cir0.Radius + cir1.Radius) / num1, -1.0, 1.0)
        num2 = math.acos(d)
        tangents.append(rg.Line(cir2.PointAt(num2), cir3.PointAt(math.pi + num2)))
        tangents.append(rg.Line(cir2.PointAt(-num2), cir3.PointAt(math.pi - num2)))
    if num1 + cir0.Radius > cir1.Radius and num1 + cir1.Radius > cir0.Radius:
        if abs(cir0.Radius - cir1.Radius) < 1E-09:
          tangents.append(rg.Line(0.0, cir0.Radius, 0.0, num1, cir1.Radius, 0.0))
          tangents.append(rg.Line(0.0, -cir0.Radius, 0.0, num1, -cir1.Radius, 0.0))
        elif cir0.Radius < cir1.Radius:
          d = Clamp((cir1.Radius - cir0.Radius) / num1, -1.0, 1.0)
          num2 = math.acos(d)
          tangents.append(rg.Line(cir2.PointAt(math.pi - num2), cir3.PointAt(math.pi - num2)))
          tangents.append(rg.Line(cir2.PointAt(math.pi + num2), cir3.PointAt(math.pi + num2)))
        else:
          d = Clamp((cir0.Radius - cir1.Radius) / num1, -1.0, 1.0)
          num2 = math.acos(d)
          tangents.append(rg.Line(cir2.PointAt(num2), cir3.PointAt(num2)))
          tangents.append(rg.Line(cir2.PointAt(-num2), cir3.PointAt(-num2)))
    if cir0.Plane != rg.Plane.WorldXY:
        xform = rg.Transform.ChangeBasis(cir0.Plane, rg.Plane.WorldXY)
        for tan in tangents:
            tan.Transform(xform)
    plane = cir0.Plane
    rc, u, v = plane.ClosestParameter(cir1.Center)
    if u != 0.0 or v != 0.0:
        xform = rg.Transform.Rotation(math.atan2(v, u), cir0.Normal, cir0.Center)
    return tangents
def RunCommand():
    cir0id = rs.GetObject("Select first circle", rs.filter.curve, False, False, circleGeometryFilter)
    if not cir0id: return
    cir1id = rs.GetObject("Select second circle", rs.filter.curve, False, False, circleGeometryFilter)
    if not cir1id: return
    cir0 = rs.coercecurve(cir0id).TryGetCircle()[1]
    cir1 = rs.coercecurve(cir1id).TryGetCircle()[1]
    if cir0.Plane.DistanceTo(cir1.Center) > 0:
        print "Input circles must be co-planar"
        return
    tangents = SolveTangents(cir0, cir1)
    ggp = GeGuidePoint(tangents)
    ggp.SetCommandPrompt("Guide point")
    ggp.Get()
    if ggp.CommandResult() <> Result.Success:
        return ggp.CommandResult()
    doc.Objects.AddLine(ggp.line)
    doc.Views.Redraw()
if __name__=="__main__":
    RunCommand()
CircleTangents.py (3.4 KB)
Lost it , sorry.
Anyways, I think that the erogonomy of Mahdiyar’s script is much better.
It might take one click more, but I like the visual interaction.
