Hi guys, my tools that has worked for years are not working under the latest v7 SR.
It seems you changed something in Rhino.Geometry.Mesh.CreatePatch() causing it to think that a closed polyline is no longer the required closed polyline it requires.
OK, so I located the bug to be in Rhino.Geometry.Polyline. If I make it from a list of points where the first point = the last then I get an invalid curve for Patch. ( I have used this for years, it just stoped working in SR 32)
So instead of using:
OuterPolyLine = Rhino.Geometry.Polyline(OuterPts)
I now use this instead where I first make a PolylineCurve and then convert that to what patch needs:
######## WORKAROUND FOR SR 32 FIX
OuterPolyLine = Rhino.Geometry.PolylineCurve(OuterPts)
OuterPolyLine = OuterPolyLine.ToPolyline()
Since I don’t know who to tag here I just tag you @dale Hope that’s OK.
Hi Jorgen - I see our best minds are looking at this now - thanks for the report.
It’s looking like this is the likely change in SR 32.
So you tagged the right guy for the question!
