Dots are not displayed in the hatches
Yep, confirmed…
I was surprised to see 71 open issues for hatches listed as “bugs” - but I didn’t find this one in there, so I created one…
@ivan.galik can you share a file as a sample? We are drawing the points, just very tiny. I bumped up the point size a little bit, but would also like to confirm that they work for your model.
Thanks,
-Steve
hatch.3dm (60.8 KB)
Thanks; that helps. I wasn’t accounting for far from origin geometry. I should have a fix for this in the next beta.
[edit] this will be fixed in the next beta
A post was split to a new topic: Print width on hatches and PrintDisplay
actually it is not
Are you seeing dots in the hatch.3dm file that you sent?
microscopic and its not visible in clipped geometry at all
now i realized that you cant adjust pattern weight in section style which is sad
i wonder if you test your fixes or blindly assume something is fixed? because it says it is fixed for current beta.
I test my fixes on both Windows and Mac under different screen resolutions. I don’t have access to your computer so sometimes things don’t work and we need to reopen the issue.
i am using the most standard configuration i believe
2560*1440 resolution on 27inch screen
Rhino 8 SR0 2023-10-17 (Rhino 8 BETA, 8.0.23290.13303, Git hash:master @ 24dadfbf2dfcd800fa6d30f72e3aebb413becab4)
License type: Commercial, build 2023-10-17
License details: Cloud Zoo
Expires on: 2023-12-01
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 6-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-8-2023
Driver Version: 31.0.15.3623
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.23290.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23290.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23290.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23290.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23290.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23290.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23290.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Are you using customized display modes?
no recently i deleted everything and installed clean rhino, purely all defaults
Ok; I’ll reopen the issue and see if there is any reason for the microscopic dots.
HI @ivan.galik here is a new build with some adjustments to the dot drawing portion of hatches. Please let me know if this makes a difference for you.
https://files.mcneel.com/dujour/exe/20231019/rhino_en-us_8.0.23292.05003.exe
hello,
i cant see any change.
can you please post how it looks on your end? (hatch.3dm file above)
Hi Ivan -
This is how that looks on my machine here:
This matches what my screen shows as well. I’m not accounting for some difference between your system and mine. This bug is still marked as open and still on my list.
tried on my other pc
Rhino 8 SR0 2023-10-19 (Rhino 8 BETA, 8.0.23292.13303, Git hash:master @ bdbf32cf54f4fdd6a528fcb0214c29cce2cdddbe)
License type: Commercial, build 2023-10-19
Expires on: 2023-12-03
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 7.7Gb)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: Intel(R) HD Graphics 4000 (Intel) Memory: 2GB, Driver date: 12-21-2015 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GT 640M (NVidia) Memory: 1GB, Driver date: 4-9-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 425.31
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-9-2019
Driver Version: 25.21.14.2531
Total Video Memory: 1 GB
C:\Users\Samsung\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Bullant\23.9.28.0\bullant.rhp “bullant” 23.9.28.0
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.23292.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23292.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23292.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23292.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23292.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23292.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23292.13303
