I noticed that there is a change of the behaviour of the Gumball, so that when I try to move an object with Gumball’s plane handle, the latter no longer will let me move the object along two axes simultaneously (XY, ZX or ZY). The only way to “unlock” that is to manually turn off the Ortho or by holding the Shift key, which is counter-intuitive, because that particular plane handle was originally made to allow free movement along two axes. If I wanted to move the object only along a single axis, I would simply use one of the arrows instead.
Also, check my video below. My previous command was setting an MPlane and while I tried to move the selected object with Gumball’s plane, right-clicking to reset its position actually activated the MPlane instead, leading to accidental selection and movement of other objects, and a messy performance of the Gumball.
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 10-7-2019 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P4000 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 4-12-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 466.11
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-12-2021
Driver Version: 27.21.14.6611
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.0.0.0\KeyShot9RhinoPlugin\Rhino 5.0\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.0.0.0
Damn, this is really odd. I started Rhino again and Gumball now still behaves improperly. Not sure what happens… So, yes, this bug is still present in the latest Service release candidate.
