Bug Gumball extrude
Hi
It worked properly in rhino_en-us_7.5.21050.01001( 20210219 version but it does not work properly in the latest version I installed
good :crossed_fingers:
Rhino 7 SR5 2021-2-24 (Rhino 7, 7.5.21055.05001 :point_down:
Hello - what is β€˜it’ exactly? Gumball extrusion?
Hi @pascal
https://mcneel.myjetbrains.com/youtrack/issue/RH-62686
https://mcneel.myjetbrains.com/youtrack/issue/RH-62638
It worked properly in rhino_en-us_7.5.21050.01001( 2021_02_19)
https://files.mcneel.com/dujour/exe/20210219/rhino_en-us_7.5.21050.01001.exe
I did this in version 7.5.21050.01001 (2021_02_19) :crossed_fingers:
Hello - currently this behavior is toggled on or off using the test command
UseGBExtrudeSrf
The default is off.
