draw a line
_extrudeCrvToPoint
output = SubD
→ result is a surface
thanks for a fix
(Edit:)
same bug for polylines.
the behaviour should be comparable to _extrudeCrv which handles lines / Polylines well.
draw a line
_extrudeCrvToPoint
output = SubD
thanks for a fix
(Edit:)
but you can repeat the bug on a line ?
not sure its a bug, can you give an example where that specific case would be useful?
let the developers decide this.
i do not see any reason, why _extrudeCrv (output = subd) supports lines / Polylines and _extrudeCrvToPoint (output = subD) should not.
example:
preparing some patches for a pentagonal opening.
… and more centric stuff within the same project … would have been really useful …
i am definitely the last one to decide on that, but that is beside the point. i just dont see much reason for this being a bug.
i had the feeling this came up already. ok while writing i found this
https://mcneel.myjetbrains.com/youtrack/issue/RH-67329
does not look like its getting a lot of attention though.
@Tom, thanks, I’ve added this thread
