(Bug/Crash) FilletSrfToRail (Mac os x)
the example i used in this post about _variableFilletSrf cases a crash in Rhino, Mac os x, Version 8 (8.17.25063.13002, 2025-03-04)
using the red curve on the planar Surface:
_filletSrfToRail only gives a partial surfaces
using the blendCrv or the pulled Curve on the vertical R20 Rhino crashes.
also send a crash report
{"app_name":"Rhinoceros","timestamp":"2025-03-11 09:42:54.00 +0100","app_version":"8.17","slice_uuid":"b453fe94-451b-3938-badf-ea49a1f6ee2c","build_version":"8.17.25063.13002","platform":1,"bundleID":"com.mcneel.rhinoceros.8","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 13.7 (22H123)","roots_installed":0,"name":"Rhinoceros","incident_id":"DB1409AB-5A43-4290-895B-964EB0E41B6E"}
thanks for a fix
kind regards -tom
filletSrfToRail_crash.3dm (2.8 MB)
thanks, I am seeing the crash reports, and attached them (not visible publicly) to
RH-86474 FilletSrfToRail: crash / hang
FYI. I’m not getting a crash with Windows OS
Also your rail curve produces a surface with very bad tangency where it connects to the 15mm rad fillet.
To get good tangency on the ends:
  1. find the centerline of both blue fillets
  2. then use Blend Curve between the 2 centerlines and
  3. then pull that curve to the vertical 20mm fillet.
If you use history on steps 2 and 3 you can edit the blend curve by using Scale command on the second from end CV and using the end CV as the origin point for the Scale.
