[Bug?] Content cache pushes result twice?
@kike I’m puzzled right now, my script seems to be OK, but for some reason when I input a True Value for the Content Cache action, it runs twice. When I press the button on the component itself, it works as expected.
Thing is, for some reason, the script enters a state where it keeps pushing data to Rhino.
This is on (8.17.25066.7001, 2025-03-07).
This works the same for the script I work on, but when I have everything referenced and recomputing it creates a loop. I suspect this is due to the action input misbehaving, because it doesn’t happen with the component button itself.
Oops, forgot to add the script itself:
Dimension Push_Simple.gh (14.3 KB)
H Intous,
This looks related, when i get a chance I check to see if in the daily build behaves differently with your file.
I’m not able to repeat in 8.19.25083.02001, i’ll send you a link for testing.
@Japhy thanks for the link, but the daily build has the same problem for me.
Dimension push.3dm (61.0 KB)
SystemInfo
Rhino 8 SR19 2025-3-28 (Rhino 8, 8.19.25087.02001, Git hash:master @ 89f78dd658462293ad5887b0b62c6a61db49c102)
License type: Evaluation, build 2025-03-28
License details: Cloud Zoo
Expires on: 2025-04-16
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 12-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.84
Primary OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 12-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.84
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2021
Driver Version: 30.0.14.7284
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.19.25087.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.19.25087.2001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.19.25087.2001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.19.25087.2001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.19.25087.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.19.25087.2001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.19.25087.2001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.19.25087.2001
Ok, i’m seeing it now.
This might have to do with button behavior Single click trigger (like a button) - #4 by Timo_Harboe_Nielsen
Hi @Intuos,
The button is triggering a True and when you release the mouse button a False.
But if you change the normal state to be also True it will not expire again the solution.
Hi @kike,
I had tried a null before, that didn’t do the trick yet. With True on normal state, it just keeps running. Same applies when I feed in a condition that is True (e.g. I overwrote a dimension text to move the line with).
For convenience I’ve added lines to denote the offset steps of 400mm, which is the amount that each push should move the line. So you can see that the movement is two steps at once (800mm) with the normal state set to Test (Null).
Dimension push.3dm (61.2 KB)
Dimension Push.gh (21.0 KB)
To be clear, this is with both states set to True:
The script moves by 800mm, whereas the undos correctly capture the 400mm movement.
Same with the True only button from the thread @Japhy linked:
Are there any other solutions or an ETA on a fix? If this doesn’t work, I’ll have to ditch this scripting effort.
If I remember correctly the Pancake plugin contains a few very helpful nodes in cases like these. I too had issues with very long scripts sometimes calculating twice. It’s a shame Grasshopper isn’t really designed to handle any sort of reactive programming.
Here are some helpful components from Pancake:
Good luck!
Unfortunalely, none of these components help me solve the root issue, but they are definitely useful. Hadn’t really used any of them thusfar, but will do so sooner or later.
Okay. I have used the True only button a lot in my scripts where I am triggering loops and such. I also find that you can usually create a quick C# component for what you need if you can explain it well to ChatGPT and the like. Just create a C# component, copy all the code that is already there as a template and give it to ChatGPT with a prompt explaining your problem. You could just copy/paste your initial post.
Also I find Heteroptera has a lot of interesting components that sometimes help achieve something otherwise tricky. Of course Metahopper is one I often use as a sort of last resort, for example to just disable or expire a component programmatically.
Happy grasshoppering.
Odd that this method of working hasn’t been fixed yet. Guess I’ll have to add the User Text from the referenced Geometry in Rhino to the geometry that I’m moving in Grasshopper, push the latter and remove the former based on a versioning system.
