Bug ClippingDrawing not Exporting Elevations - Rhino 8
The exporting of elevations fails.
Meaning in a set of ClippingDrawings, the ones that are not sectioning the geometry fail to export to DWG. The drawing is there but the export fails.
A workaround for now is to unlock and select objects of all the layers of that section and export it traditionally. Same export setting work this way.
Thanks, N
tagging @rajaa
@user_9123125 @rajaa
I edited the title because it is not only failing the export to dwg but also to 3dm.
Another work around is to make a surface that is sectioned by the clipping plane outside of the geometry.
I see it. Working on it here…
RH-80885 is fixed in Rhino 8 Service Release 6 Release Candidate
