seems like CreateFromTaperedExtrude is not working as intended.
Planar polycurves, that are not parallel to the x, y or z plane don’t generate any breps.
I have tested it with an selfwritten component and the pufferfish component, neither work.
FYI: non-planar polycurves work perfectly fine
// Grasshopper Script Instance
using System;
using System.Collections;
using System.Collections.Generic;
using System.Drawing;
using Rhino;
using Rhino.Geometry;
using Grasshopper;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
public class Script_Instance : GH_ScriptInstance
Members:
RhinoDoc RhinoDocument
GH_Document GrasshopperDocument
IGH_Component Component
int Iteration
Methods (Virtual & overridable):
Print(string text)
Print(string format, params object[] args)
Reflect(object obj)
Reflect(object obj, string method_name)
private void RunScript(
Curve curve,
double distance,
Vector3d direction,
double angle,
Point3d point,
out object a)
// Write your logic here
a = null;
a= Brep.CreateFromTaperedExtrude(curve,distance,direction,point,angle,ExtrudeCornerType.Sharp,0.01,0.0);
Taper_bug.gh (20.5 KB)
