#bug Blocks in Rhino 8 SR11
This is a file with meshes (MeshBoxes with 1 face per dimension), then included in a block definition. Once the block is created, this happens (left: original geometries, right: block instance)
this affects also rendered views:
If I double-click to modify the block instance, things look fine again:
After clicking ok things look fine again, but if I select the block the display misbehaves again (as per first image).
Here’s the file with my geometries:
bug.3dm (75.8 KB)
And here’s my System Info:
SystemInfo.txt (2.9 KB)
The bug occurred while teaching a class, and only some students experienced it, apparently independently from their system configuration (Win, Mac, video card).
Hi Alessio
I’m not seeing this here.
Does it make any difference if you disable Enscape and restart Rhino?
Nope, no difference after disabling Enscape.
EDIT (addendum): I’ve saved the same file as Rhino 7 version and the bug does not present itself in Rhino 7 (even with Enscape enabled and loaded).
bug_R7.3dm (74.7 KB)
@wim any updates? Meanwhile, I recorded a video where I replicated the bug:
@wim any news on this front?
I made further tests, the issue seems to appear in Rhino 8 with mesh-only blocks, no matter the source:
. if any other geometry type is included in the block, the issue is not present
. if I import blocks containing only mesh geometries made with Rhino 7 the issue appears
Again, the issue is not present in Rhino 7 (exporting or even copy-pasting problematic blocks from Rhino 8 to Rhino 7)
Hi Alessio -
It looks like we had something similar on the list, and that issue was fixed for Rhino 8.12 → RH-81019 Display: Some objects loose their surface shading when added to a block
The only thing that is not the same as what you are reporting is that this looked easily reproducible and visible to all users.
At any rate, could you try the latest 8.12 release candidate and see if that fixes this for you? If all goes well, 8.12 will be the official SR tomorrow…
Ok, I’ll give SRC 12 a try right now and let you know how it goes
Yep, that was it, no preview bug in SRC 12!
Please ignore this message: it was not a bug - I realized the blocks themselves had a “wireframe” custom object display mode set.
Hi @wim, sorry to report that the bug manifested again today on SR12:
Same dynamics: once I enter edit block mode, things look fine, then back to the buggy view.
What’s new from before is that this occurs only for some block instances, and in block definitions where not only meshes but also other kinds of geometries are present.
