Hello!
I found a bug in the behavior of the relay component.
If you create a component when Lock Solver is enabled, and then remove Lock Solver, then all created Relay components are attracted to the cursor. It is very uncomfortable. It happened after the update. Someone faced such a problem?
7 SR 14.
can’t replicate this on V7 SR15 (7.15.22029.15001, 2022-01-29)
just one thing, it looks like there’s actually some lag betwheen the moment you start dragging a relay and when it actually starts following the pointer, it also looks like becoming green while standing on the original location, and only after a split second it gets dragged (maybe it’s just the recoirding?)
