Create a dimension with the arrows on the inside and the text on the inside.
In the properties panel, change the ours to the outside.
The text moves to the outside as well but the “Fix Text” dropdown still says “Inside”.
Hello- that does noyt hgappen here so far, if I understand what you are doing - are you using one of the built-in dimension styles or your own? I guess best to send a file with the dimension as initially placed and I’ll see if I can reproduce.
Problem Arrows.3dm.zip (17.1 KB)
Here is a similar problem. Change the dimension arrows to AUTO. That moves the text without changing the dropdown.
Hi John -
Thanks. I’ve reported that as RH-71499 Annotation: Styles: Arrow override changes Fit text property
