Bridge between Spheres
I’m working on a project involving a wristband, watchband, or glove. I have two approaches in mind:
  1. Soap bubbles
  2. Soap bubbles with reduced surface tension
The second idea is illustrated in the following image:
For the first approach, I tried using the Cocoon Plug-In, but it either resulted in a discontinuous structure or a single large blob. I also attempted to use Cocoon curve charges, but they didn’t connect with the bubbles.
As for the second approach, I explored using the “Pipe” function. However, I’m struggling to make the pipe ends tangential to both spheres while ensuring a minimum radius of half the sum of the sphere sizes.
cocoon with 40 points
cocoon with 70 points
cocoon file :
Cocoon strukture v1.gh (15.7 KB)
soap bubble file :
Soap bubbles v5.gh (13.5 KB)
I hope I have explained the problem clearly. Thank you in advance for your assistance!
Something like that ?
Yeah that looks good! I need to translate into 3D but the Shape is just as I imagined it.
Thanks lets see if it works
Bridge spheres V0.gh (13.8 KB)
It uses implicit modeling tool Jellyfish and other plugins.
The pOd can be downloaded from here.
You can create the tangent cone or truncated cone around two spheres by finding the tangent line , angle, radius …etc
Tangent lines to Two Circles
cone around 2 spheres.gh (23.8 KB)
Great contribution, but I think it might be a bit complex to integrate into my code :smiley: .
I think i might have had the wrong approach with the tangents but ill give it a shot.
I am getting really cool results with this. I think i’ll continue with your approach thanks!
I was wondering if there was a reason the pod - closest brep button isnt showing up for me after loading the plugin? I’ve added all the updates as well from food for rhino but I cant seem to figure it out. Any help would be great! Thanks
the POD link doesn’t work, google drive won’t let you in because it says it violates their rights etc…
“Sorry. You may not access this item because it violates our Terms of Service.”
try isopod
ah okay if it’s Isopod I already installed it on my work PC, I hadn’t installed Isopod on my home PC, and Pod just seemed like another plug-in to me Lol
Here
thanks :muscle:
