Brick Facade
Hi, has anyone done something similar to this?, I’m kind of new in Grasshopper and need an idea of how to model a brick facade similar to this
I can see a method using Paneling Tools or Pufferfish that would work.
That should be acheivable - make a wavy deformed underlying surface - project a grid of points onto it, evaluate the surface at those points in order to get a series of planes, and use the orient node to move a ‘brick’ to each of those planes.
You could have a read of the Grasshopper primer;
https://modelab.gitbooks.io/grasshopper-primer/content/1-foundations/1-5/1_surface-geometry.html
