Brep - plane intersection doesn't work right
the def is attached
plane X brep bug.gh (29.8 KB)
It is a known limitation with intersection when there is a singularity (the point at the lower tip of your brep). I’ll add your example to the bug list. For now, you workaround it using the following solution. I hope this helps
plane X brep bug_RI.gh (11.4 KB)
thank you for the clarification and the workaround!
