I am using the Brep/Plane Intersection command and 4 out of the 5 intersections work perfectly to waffel struc. attempt.3dm (3.9 MB) waffle struc. attempt 17.02.09.gh (12.5 KB)
produce closed planar curves. The one in the middle, however, only produces a line at the bottom of the Brep and fails to intersect all the way around.
Yea, for some reason the problem is due to it being right in the middle and touching the tip of the cone… guess it could be a bug because with other geometry it works fine.
