Method & issue:
I try to create cut plane to divide surface by using Brep/plane.
As the circle on the image, there are no curves on the half of surface.
I am guessing that is because of “intersection failed” in the Brep/plane.
I have tested many way but I could not solve this issue.
Could anyone help me to solve this issue?
I am curious about the difference between mine and your solution.
Your solution is much better than mine.
In order to reset plane of the selected points on the curve, I used Remap numbers.
Could you explain a bit more what part of my script went wrong?
If I know my mistake, I will make same mistake again.
Hi Archisong
Your script got length of curve was wrong.
when you used construct domain component, Z coordinate start at 0 of value.
You should get the Z coordinate of the start and end points of the curve.
