Brep distorsion after boolean difference (SDiff)
The output of a boolean difference is distorted from the original, anyone knows why and how to fix?
distorsion_brep.gh (45.2 KB)
That’s just the render mesh. You can check by creating contours…
Thank you!
I tried to check converting to a mesh and it seemed distorted too, probably for the same reasons.
The operation depends on the tolerance set in Rhino and what’s displayed depends on the quality settings in Grasshopper which you can edit. It’s the button in the upper right corner.
I just ran TriRemesh with an edge length of 0.5 mm and after 10 minutes it looks pretty nice.
Mesh Brep requires custom settings.
