Rhino 7 for Mac keeps crashing
I’m not sure what’s happening. The first crash happened when I switched to Artistic view for fun, so I assumed it just overloaded the computer. But now, the file will stay open for at most five minutes before crashing after I rotate around the model. My Rhino 7 is up to date, and I’m not sure what else to do.
Crash Report that it gave me:
Process: Rhinoceros [44338]
Path: /Applications/Rhino 7.app/Contents/MacOS/Rhinoceros
Identifier: com.mcneel.rhinoceros.7
Version: 7.18 (7.18.22145.08132)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Rhinoceros [44338]
User ID: 501
Date/Time: 2022-06-09 11:18:51.192 +0100
OS Version: macOS 11.6.4 (20G417)
Report Version: 12
Anonymous UUID: AA70D9AB-C66E-55BF-28E5-6B81BCB1C8FA
Sleep/Wake UUID: 60BD933A-1092-49EA-B91D-7D07319DC23D
Time Awake Since Boot: 400000 seconds
Time Since Wake: 5000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 tid_103 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000048
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [44338]
Hi Darian -
When Rhino crashes, does the Rhino crash reporter also pop up, or only the macOS one?
In Rhino, please run the SystemInfo command and copy-paste the result here.
These are just work arounds.
  1. Reboot the system Four days used to not be a lot of time. I worked on computers that were up for years with a reboot but these days where bugs are more acceptable rebooting can fix things.
  2. Do a disk repair in Disk Ultility.
  3. Make sure you have a good chunk of disk space available.
  4. import the contents of your Rhino file into a new file.
That was from the Rhino crash reporter. Here’s what I get from System Info:
Rhino 7 SR18 2022-5-25 (Rhino 7, 7.18.22145.08132, Git hash:master @ a2f70299f1d18c46806894c03a86e954fb7ab656)
License type: Evaluation, build 2022-05-25
License details: Cloud Zoo
Expires on: 4543286-01-22
Apple macOS Version 11.6.4 (Build 20G417) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro11,4
Language: en-US (MacOS default)
Intel Iris Pro OpenGL Engine (OpenGL ver:4.1 INTEL-16.5.8)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1536 MB
Graphics: Intel Iris Pro
Displays: Color LCD (295dpi 2x)
Graphics processors
Intel Iris Pro (1536 MB)
Color LCD (1920 x 1200)
USB devices
Apple Inc.: Apple Internal Keyboard / Trackpad
Broadcom Corp.: Bluetooth USB Host Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.18.22145.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.18.22145.8132
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.18.22145.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.18.22145.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.18.22145.8132
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.18.22145.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.18.22145.8132
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.18.22145.8132
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.18.22145.8132
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.18.22145.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.18.22145.8132
If it were me, I’d do a PLIST reset:
https://wiki.mcneel.com/rhino/mac/resetprefs
The Intel Iris GPUs are poorly supported.
If this turns out to be an OpenGL driver crash, we’re at the mercy of Apple to fix them.
I see you’re running macOS Big Sur.
There is an 11.6.5 update that would be worth installing too.
@Darian_Bertrand
I do not see any recent crash reports from you.
When Rhino crashes, enter your email address and describe what you were attempting to do when Rhino crashed.
Sent it in, and let us know you sent one so we can goo look at it.
Pursuant to that, is there anything specific you can do in Rhino that is likely to cause a crash?
