Hi there!
Immediately after the lastest Rhino update (8 8.24 coming from 8 8.23), the Grasshopper definition I’m working on failed.
The culprit turned out to be a bounding box which hast become inaccurate. Since I use Rhino two Macs, I did some tests on both machines, one updated, the other still on 8 8.23
The failure manifests as a wrong Z-Height after deconstructing the BREP. Although the error is very small, it made my definition fail, because I wanted to extract all points within a specific plane (hence the Z-value), and use it for a polyline. The failed BoundingBox produced a wrong Z-value for the plane and no points could be extracted.
I prepared two examples to demonstrate the problem. The first example uses the actual part I’m working on (a fantasy Blaster to be 3d Printed some time) and a purpose build test body. The frustrating part is, that the bounding box only fails on the actual part I’m working on, but works fine on my test object.
I already solved the problem with a simple workaround, but it is somehow very unsatisfying that this inaccuracy suddenly appears after an update.
Example 1: Failed BoundingBox on Mac mini with latest Rhino Version (8 8.24) on my working part:
Example 2: Correct BoundingBox on Mac mini with latest Rhino Version (8 8.24) on my test object:
Example 3: Correct BoundingBox on MacBook Air with Rhino Version 8 8.23 on my working part:
Example 4: Correct BoundingBox on MacBook Air with Rhino Version 8 8.23 on my test object:
Blastertest.3dm (2.8 MB)
BoundingBoxTest.3dm (2.9 MB)
BoundingBoxTest.gh (12.7 KB)
SystemInfo_MacBookAir.txt (4.6 KB)
SystemInfo_MacMini.txt (4.8 KB)
Again, I’m just posting for information only. Nonetheless I’m interested in what’s going on, and if it can be solved.
Thanks!
