Boundary Surface fails to create the surface within the closed curve?
I closing a bunch of curve pairs by connecting their open ends with line segments. However, there is this one case which fails; the joined curve consists of 5 vertices (see explode curve component) and as a result, the Boundary Surface fails outside the closed curve.
Boundary surface fails.gh (19.3 KB)
After a rebuild it works, but the bug remains.
wow, nice spot! :+1:
meanwhile the bug gets solved I’d go for network surface:
Boundary surface fails_Re.gh (12.5 KB)
edge surface command also works; i think it has to do with the input curves - if you use the close curve command, it will create two closed planar curves, then apparently trims the smaller out of the large one
the original code works with two randomly drawn curves in rhino; i’m not sure why it doesn’t work for the curves that are internalized.
This method has always worked for me for years and years, but has become buggy for some reason. I’ve never had this issue before.
Version 8 SR23 (8.23.25251.13001, 2025-09-08)
Fit Curve helps
Boundary surface fit.gh (6.3 KB)
are the internalized curves two trimmed curves?
They are offsets.
my feeling is there is something to do with the degrees of the input curves? since one is an offset of the first.
Looks like the offset flipped one of the curve domains:
E: even Fitcurve leaves behind a 5th vertex. With 4 curve segments, there should be 4 vertices (in this case). The problem is that there is an overlapping vertex.
E2: A rectangle has 5 vertices too when exploded, so nvm.
but a deconstruct brep gives you 4 vertices :smiley: i think when you explode a closed curve, it gives you the last vertex identical to the first one: you have n curves, and n+1 vertices as each curve has two end points. i think the issue is with the input curves, specifically with the second being an offset of the first, but i can’t yet say what.
or Pull Curve or Sweep
@Intuos Yeah. The seam of a closed curve is repeated in the vertices.
Interesting. How did you do the offset?
Offsetting the outer curve in Grasshopper results in a correct solution.
Boundary surface offset.gh (4.7 KB)
Yes, it clearly is the curves that are the problem, that much I’ve figured as well.
It would be nice to know how the offset was created.
Sorry had to leave earlier.
Here’s the file with the offset with an internalised curve. Notice that you can bake the curve to replicate the screencast I posted earlier.
Boundary surface fails.gh (14.8 KB)
Here’s what I see when I open your file.
PS: I baked your previous curves so I could look at them in Rhino but could not see anything special.
What’s the error?
My file is in meters FYI.
E: I should increase the tolerance a little. :rofl:
Disconnecting the plane input solves the problem on my end.
What Rhino file do you use with the definition?
