Oops… There are a ton of hidden objects in the file I uploaded. Here’s another copy where all the hidden objects have been deleted, leaving only the two in the images I previously uploaded. The behavior is the same; BooleanDifference fails with the two objects and succeeds when the sphere’s radius is reduced from 200 to 199.9.BooleanDifferenceFail.3dm (15.4 MB)
Hi Mike- the problem is a failure in surface-surface intersection - you can see it by looking at the results from Intersect - the expected curve is missing a chunk. The reason the file is so large is th\at there are 6 unused block definitions - Purge gets rid of those.
( the BD works in the V7 WIP)
