Boolean Difference help
Hi, I’ve been trying to boolean difference multiple things at once but it just says “Boolean difference failed”
Multiple different reasons Boolean operations fail. One common reason is the two objects have coincident or nearly coincident surfaces. Another reason is the intersection of the objects may not be either closed or extend to the edges of the surfaces.
If you post an example of what is not working for you it may be possible to provide specific assistance.
