Boolean Difference fail yet appears perfect
V5
Why does Boolean Difference fail.
I use red to cut from a test block, works.
I use mauve to cut from test block, works.,
I use red to cut from mauve, fails.
No naked edges,
all valid polysurfaces.
Boolean difference fail chimney yet good intersection.3dm (104.1 KB)
Oh I do love Boolean Differences, until they fail.
This V5.
Steve
Apart from the ones at the top of the purple object…
Match the top to the sides properly and the boolean difference will work
I thought I had used Naked Edges as it said none exist.
…and how become it cut through a test block ?
Steve
I’d guess the intersection didn’t go through the naked edges.
that naked edge was on top of the chimney ’ inside cutter thingy’.
it was outside of both my chimney bricks and also the test block.
Puzzling.
Is there a button I can make that runs all the checks needed to make sure all is good to go for booleans ?
What would be the code to place in the button please.
Is there a repository of useful user made custom buttons we can look at and use ?
I have some useful ones I could put there, how would one do that ?
In fact I will make a new post for that, as that would be useful for all to see it in the subject heading.
Cheers
Steve
the objects you like to use for boolean operations should be “closed polysurfaces” in the object properties panel.
No, the naked edges are on the purple chimney piece, not the red cutter. Use _Intersect with the two objects to see where the intersection curves lie and how they encompass the naked edges (you’ll need to zoom in).
Hi, Ok
also:-
Steve
No, not without programming. But I would just try a Boolean and if it works then all is good. If it doesn’t work then, and only then, would I investigate. Key investigation tool is to run intersect on the objects to see where you get gaps, then engage brain to work out why.
