I’m trying to carve (booleandifference) out a notch using a block I created. Instead of subtracting the block from the rod, it’s welding the two together. The same process worked fine on the other end of the rod. Any advice appreciated. thanks
You pick the two objects (first, second) then it shows you a preview of the two unioned. If that’s not what you want left click and it will show you the next option (I don’t remember the specific order, but it will do difference, A+B, A-B, etc. it will keep going around the circle of choices with each left click until you decide what you want (if any) then you right click (enter) to accept.
