Blocks are broken in latest WIP
Hi McNeel,
I cannot use latest Rhino WIP because I am quite dependent on blocks, and they are not usable at all. Wether I try to created a new block, or to only select a simple block with a box created in RH7, Rhino crashes instantly.
Here is my SystemInfo, in case my system would be the culprit.
System Info.txt (5.7 KB)
Hi @flixchameroy I can repeat this, thanks for reporting,
RH-74941 Crash when creating a block item
Hi @Gijs, is there a way to downgrade to previous version if I want to continue using WIP this week ?
Hi Felix -
If Rhino is automatically downloading updates, you should find the pervious version in the following directory:
%userprofile%\Appdata\local\McNeel\McNeelUpdate\DownloadCache\
Sorry @wim but I can’t find this directory, is it a macOS path ?
Hi Felix -
No, sorry about that. You can find the previous version here.
Thanks @wim ! Is the issue fixed ? (meaning, could I install the new WIP ?)
Hi Felix -
RH-74941 was fixed and tested with a version that is older than the current public WIP, so, yes, you can now install the new WIP.
