Blend Surface in Grasshopper
Hi there.
This might be very easy, but I could not find a solution.
Is there a blendsrf in GH?
How to blend to surfaces in Grasshopper?
Please see the
pic.
Thanks.
Right now, there are various Rhino commands that have no equivalent in Grasshopper. You could try the plugin Flexibility, because it has many of these commands.
that’s alot of tools :sweat_smile: :beers:
I’m not a fan of redundancy though:
Not sure why different developers would have the same tools…
I’m trying to use Blend Surface from flexibility. Great add on by the way.
The use case is a blend surface between the ends of 2 cylinders. Like a fancy loft with either tangency or curvature.
Flexibility creates the blends well. It looks great; then I try to join the breps and they won’t join
When I bake the geometry, Rhino won’t join the breps either. But when I re-create the blend surfaces using the normal rhino commands with the same settings, the geometry looks identical and successfully joins into a polysurface. Any idea why the gh created geometry would have a different join behavior than the rhino geometry?
Hi can you send that (*.gh )?to test and find bug?
Hi there,
anything new in 2025 ? native component or other ?
2 similar posts,
and aslo
thanks
CC
Depending on your needs, you now have access to Blend Curves which you can use as rails for a Sweep2 to create similar surfaces. But as I said, these kinds of tricks are circumstantial.
