Hi Rhino forum, A question on Blend Curve.
Here’s an example , 2 parallel lines drawn, next would want Blend curve somewhere between the ends (Anywhere along the lines) , let’s say midpoint to make it easy. Blend curve wants to go to the ends( as expected I would guess). I went through a couple of the options without any success. What am I not doing right to get the start point to be where I choose and not the curve ends? Maybe using the wrong tool? - thanks for any feedback,Mark
you are doing nothing wrong, simply drag the endpoints to where you want them to go-
That should indeed work.
Even if CurveEnd option is set by default, it is normally possible to pick the blend start point and relocate it elsewhere later.
If I am not wrong, it is a two step procedure.
- One click on the blend start point to locate it
- One more click to relocate it.
Regards
Rodolfo Santos.
Hi Kyle, would it be bad to pick the place you want the curve to start vs the tool saying I am going to the end of the curve? I am sure someone has spent some time to make it the way it is.—Mark
Thanks Santos, in the example you provide, it works great. What if you curves are 70” long, I have to run back 70” to find the ends to move them. A small pain, but doable. —-Mark
Both
I would choose to relocate it manually and snap to the End Point, I find this strategy more secure.
Regards
Rodolfo Santos
I see that now, Kyle. Thanks I tried it in V6 and couldn’t get it to work. Glad V7 it is working
Tried it again in V6 . Works fine there too. My dope!
