Blend 2 open surface edges to 1 open surface edge
Trying to blend these open edges to each other.
blendSRF.3dm (544.5 KB)
reducing the complexity of those surfaces will make you life a lot easier..
I’d break it down into manageable 4 sided sections, and the last 5 sided sections you’ll end up with, the patch command in v9 WIP may be your best friend. That would be a bit of a brute force method.
There are more sophisticated methods, like the 5 sided areas, make a larger blend surface and trim it back to get your “arch” similar to how a signet ring is made. (see this video)
Thank you!!
I would arrange the surfaces like this
blendSRFx.3dm (383.0 KB)
If the above solutions don’t help and in the future you endure a more complex case with highly curved shapes, perhaps you can try the approach shown in this video:
