Please help me with my problem. After installing rhino 7, the materials are displayed in black. The graphics driver was updated, reinstalling rhino did not help. the version is clean
System: GTX 3090 ti, i 9 12900 kf, msi Z 690 board.
Everything works on the laptop. What’s the problem??
Thank you for your help. Help me…
Please run the Rhino SystemInfo command and post the results.
Generally black indicates OpenGL problems.
Rhino 7 SR1 2020-10-25 (Rhino 7, 7.1.20299.23101, Git hash:master @ 8d9ce31398d29589acec390d2167dc68806d5b79)
License type: Commercia, build 2020-10-25
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce RTX 3090 Ti (NVidia) Memory: 24GB, Driver date: 10-6-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 522.25
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-6-2022
Driver Version: 31.0.15.2225
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
D:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20299.23101
D:\Program Files\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit”
D:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20299.23101
D:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20299.23101
D:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
D:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots”
D:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20299.23101
D:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20299.23101
D:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
D:\Program Files\Rhino 7\Plug-ins\Displacement.rhp “Displacement”
Other than your Rhino is 2 service releases behind, your SystemInfo looks great.
See if updating your Rhino helps:
https://www.rhino3d.com/download/rhino-for-windows/7/latest
Updated to a new version, unfortunately the problem was not solved
Materials are black
We will need small sample file that shows the problem.
Maybe make a new file with a couple Boxes. Apply your materials and see if you can get it to have the problem?
Send it to tech@mcneel.com and reference this message URL.
We’re about done for the week.
Here is a screenshot from your file using a default Rendered display mode.
I do not see that you have used any materials.
Are you using a default Rendered display mode?
What does your screenshot look like?
Your Rhino version is still 7.1 with the sample file you uploaded. You’re not 2 service releases behind, you’re two years worth of service releases behind - that is twenty two releases behind.
Ensure you really update to 7.23, see if the problem still exists, then save a new file with the very latest Rhino version, and share that file.
