Are there plans to create a material library that allows users to associate metadata with it? Similar to what we see in Revit. This would be very useful when it comes to scheduling wall/floor/ceiling finishes.
Hi @Julius3 I add this request to the wish-list. You can handle this right now with the custom parameters. https://youtu.be/rdX7I79qTTI?si=xu4WrmQ4uVJR2TZW
Using Grasshopper, you can automate the process of calculating the area, volume, length, etc, of an object or a part of it, and assign the corresponding value of a custom parameter (i.e the “Cost”).
You can see an example of this here: How can I create calculated parameters with Grasshopper? - VisualARQ
