i am curious, if there is a way how can we gather information from common rhino objects?
1st question: I guess we are not able to automatically generate fe. volume (which is added via object/document parameters). It means that we allways need to specify the value manualy, right? Wouldn’t be fine to extract data for rhino objects the similar way as it is with VA objects?
2nd questions: Regarding to the 1st question, it would be also nice to have a possibility of creating tables including all these “interactive” values. (Talking about rhino objects)
If this is possible now, I just do not know, how to achieve the required behavior.
Hi @petumatr,
I add your vote for this feature. When it is done VisualARQ will be able to calculate the area, length, or volume of Rhino geometry and list it in tables. And of course it will be recalculated automatically if you edit the objects. Meanwhile you will need to create the Parameter “Volume” and assign the proper value to each object manually (or you can do it automatically from Grasshopper).
Hello!
Well, both. We are regularly doing building mass studies here, which means basically placing boxes with planes as floors, and listing the numbers - areas, volumes… what the investment guys are interested in.
Will look for a Grasshopper way to do this. Could this work?
Thanks!
Edit: did this in Revit a few times already. Works, but would like to avoid…
