I would like to build a mesh over point cloud.
Is there any way to see point cloud better during building polygons? I mean without any paid external plugin. How to see point cloud better here? Maybe scale points?
Hello - you can set point cloud point size in the display mode settings
@mdesign - you can also have a play with testPointCloudStyle
- this is an unsupported test command - use at your own risk - but might be useful.
@pascal :
Thanks a lot. What about transparency and temporary clipping?
Edit: and shading
Hello - Transparency should follow the alpha on the object orlayer color but it looks, at the moment, like it does not… Clipping planes should work however.
RH-66113 Display: support transparency in point cloud display
Can I use any kind of pseudo shading with point clouds?
Hello - only through testPointCloudStyle
> set spheres or boxes.
