Best way to design sheet metal parts in rhino, for ordering. (bends, etc)
This might be a super obvious to you. But I would like to know how you design your sheet metal parts. Id like to design parts like in this picture, that i can then order on sites like Xometry etc.
I guess, Im wondering if rhino has a function that easily allows for simple bends, without doing a lot of fidgeting around.
I know most often people use SolidWorks to do this kind of job, but i would really love to do this all within Rhino. What does your Sheetmetal workflow look like? :mechanic:
A couple on food4rhino.
No K-Factor
With K-Factor
Thank you so much, i will check them out!
Carl,
I know this is a really old post, but I thought I’d give you my 2 cents… or sense… whichever.
I have been trying to learn Fusion 360 for awhile because it applies to my field way more than Rhino these days, but I’m stubborn and old, so I’ve come up with a very successful work-around for sheet metal in bare-bones Rhino.
Most of my sheet metal parts I order through Oshcut here in UT (they ship, definitely check them out. They’re always on point). What I like about them is they have an extensive materials library with K factors, bend radii, everything you need to know about pretty much any bendable metal.
My workflow now is checking the material thickness I need, looking up the bend radius / radii, then building my parts drawn by lines that are the interior face of the part, then filleting them to the correct bend radius, then offsetting by material thickness, then extruding into a solid. After awhile, if you use enough of the same materials, the radii and offsets become second nature.
It’s a bit tedious, but once you get the hang of it, you can make pretty complex parts with no plugin, no unrolling, no patterning, nothing. Best part is Oshcut lets you upload your part files as .3dm or step and it will run them through their brake software and let you know if you have any collisions or if there’s a problem with the “non-uniform thickness” that can sometimes happen building parts this way. Sometimes I upload just to check that my part is good then send it to a more local-to-me laser cutter / bender that accepts straight up step files and converts everything on their end. Maybe you have someone like that near you?
Again, not ideal or as easy as Fusion (once you get the hang of Fusion), but it IS a possibility, and learning this workflow has helped me tremendously in design / fab.
Hope this helps!!
–Matt
Horick Architectural
SLC,UT
Thanks Matt, that’s perfect - just the easy method I was looking for, without stuffing around with plugins. And thanks for the tip about Oshcut - now to see if I can find such a good manufacturer in Australia!
Did you find a good supplier in Australia? Do they do the unrolling for you?
The sheet metal bend script posted above worked well for me. I added a new thickness based on a mild steel sheet metal guage. Its clever python inside a simple to use grasshopper script. give it a go to optimise your workflow
Little plug here @Carl_Johan_Jacobsen
Beginning of this year I started with sheep metal which can take in a non manifold brep and converts it into a sheet with the possibly to then unroll it or apply bendreliefs and things like that if you want to give that a try:
SheepMetal
