Best Rendering Engine for Rhino Workflow with Mac
Can anyone recommend the best rendering engine for easy workflow with Rhino Mac?
I often will design buildings and interiors by modeling and trying different materials in realtime. In the past I have used VRAY on windows computers but that doesn’t work on mac and parallels is glitchy.
Is there a program where you can easily update the model in rhino and it updates in the rendering program? Unreal and Blender seem to be a big process for moving between the two.
Thank you!
Hi Clair,
I recommend to check out Bella render
https://bellarender.com/
Created by former Maxwell render developers.
I have been using Maxwell for 10+ years, but since development is somewhat stalling and the rhino integration is not so good since rhino 6, I am switching.
Cheers
Daniel
Hi Claire,
you could also start with the integrated Rhino 7 render, which is now based on Cycles from Blender, and its good.
Cheers
Michael
I have had some success with Keyshot in the past. It would be great if V-Ray for mac was developed but last time I checked there has not been any progress made.
I also recommend Bella.
Very good integration, excellent quality, good speed and actively developed.
Thanks everyone, super helpful.
Yeah I do get ok results from the Rhino built-in render engine, but find it incredibly slow.
I will give Bella a try, sounds like that is faster!
@Claire_Salinda What did you end up using?
Enscape is fully compatible with Macs and has a Rhino plugin.
Similarly Twinmotion but with some slight limitations. Also TM is free for firms doing under $1M annual revenue.
I wrote a whole guide on which renderers are compatible with Macbooks, and what the limitations are: 10 Best Architectural Rendering Programs for Mac
