I often encounter the problem that I have multiple surfaces, that can be intersecting each other.
When using QuadRemesh in Rhino, the tool seems to mesh each surface independently. As a result, the shared edged is not a compatible mesh, and can’t be used for FEA.
What is the best practice to make a compatible mesh at the shared edge between 2 surfaces?
Regards
Tien
