BEST Laptop for Rhino and CAD? šŸ’»
I considered the MSI too, but went for the razor edge 15 with an rtx2070, but didn’t like the green logo on top so I bought a dBrand pure black sticker to the entire top and it turned out very sleek and nice IMO.
It looks like this (not my picture) and I sat the keyboard to an orange hue.
The cooling is great when you consider the massive hardware that is inside it, it’s completely silent when web browsing and writing emails / word docs and then revs up the fans to about a macbook noice level (very good in other words). It’s built like a mac and the screen is great (Went for the fullHD, not the 4K, since for me this is an on the road/VR/Presentation machine and not my main work horse).
The only thing I dislike is the keyboard. It’s great to type on, but the key layout is a bit odd for coding. Musle memory don’t like keys that are arranged. This is mainly the because of the FN key and the arrow keys. AND the backlighting doesn’t light up the secondary key functions, so fidning all those #%¤!§ letters is difficult when it’s dim light in the room. But I still love it. It’s thin and robust and looks good, but a bit pricey.
Oh, and the keys and the surface needs to be wiped quite frequently as finger prints stands out quite a bit.
I am considering it as well but how much was it? and is it just for presentation or you do some actual Rhino/Cad work on it?
I bought mine in Norway and got the last one with the 8750h processor since it is only 5% less powerfull than the 9750h, so I got it cheaper. What the price is in your country you will have to check.
I only got the RTX to be future proof since I use it with VR, if not I would have gone for the 1660 I think.
And I got the 256GB SSD but have ordered a 512 to replace that. (I wanted a usb ssd to store stuff so I will put the ā€œoldā€ one in an enclosure for that) And I went with stock 16GB ram.
I use it for modelling too, but that drains the battery quickly of course, so will it do on all laptops since both the cpu and the gpu is used much.
Interesting to read through this thread because I’m in the same boat. I recently stumbled upon an ad for the LG Gram and have been contemplating it as my next rhino laptop. I have my workhorse tower in my office, I just use my laptop to get some modeling done on the road and I hate how heavy my current set up is (6 pounds!). 15.6ā€ display, 16gb ram, core I-7, 2.5lbs and under $2,000. Anyone have any advice on this?
Hi Jess.
That’s a nice looking machine, but you will probably not be happy with the Intel UHD 620 graphics if your models are complex or if you need rendered mode. (Not talking about raytraced mode, just ordinary rendered)
What kind of modelling work do you do?
hej @bodia27,
I am with @Brenda on this one. In terms of performance/cooling I think P53/P73 is a good choice as the body allows for enough space inside the laptop in order not to make too many compromises when the workload on the machine is persistant. Plus it has all the ports that you may want. I have bought a P51 (Xeon, Quadro and 4k, 500GB SDD and a 1 TB HDD) at the time and I very happy with it. Actually I also got it for the sturdyness and most of all for the ability that you can replace stuff. There’s a maintenance manual that comes along with it. So if you want to upgrade RAM or put in a larger/faster drive for instance there is no problem. There are actually screws on the machine so it’s not glued. I’ve openened it several times since and it’s easy to do.
But then again it really depends on the use case. You mention you don’t want it to be bulky? Do you mean heavy or actually sleek? My machine is indeed not super light, but it is my main computer for that matter and I want to be able to work wherever I need to. (Sometimes this also is in a messy workshop with tools or a train or what have you) Hence also sturdy > slim in my case. Design-wise the Thinkpad is a classic, I think. It’s not too shiny or polished, but the black body is iconic :wink:
But if you don’t do a lot of rendering or complex GH definitions you may not even need to max out on specs for Rhino and CAD alone and if you are more comfortable with a lighter one, it’s probably going to do the job.
When i meant sleak i meant that looks like macbook/razer blade/msi. I ended up getting Lenovo P1 that i mentioned earlier for $1600 (used). Good deal no?
Hi Holo,
I do packaging design so I’m designing lots of bottles and flexible pouches (curve network is my friend!) Mostly I am responsible for the models and my coworker does the renderings (Mostly…)
What exactly will happen that will be undersireable. Will is be slow to rotate and save, or have jagged edges? Also, is it possible to upgrade a graphics card on a laptop or is it pretty much you get what you get and thats that? I appreciate your advice!
Well I do need a machine that models more complex this including residential houses, and renders them as well, but its not full time thing yet, with a lot of design and Photoshop/Premiere Pro as well. P1 seems like a good compromise with the new t2000 card and 32gb RAM? Am i correct on it? P53 or P73 are a bit too bulky for me.
Hi Jess, my best advice is that you install the Rhino evaluation on some friends laptop with an intel card and try it out with your files.
Typical issues are not handling big or many bitmap textures due to vram limitations, bad ghosted quality and performance, overall rendered performance etc. Aa can also be an issue, but should not.
Maybe it’s good enough for you.
You can not upgrade a laptop GPU (graphiccard) but some models support eGPU if you wan’t to fiddle with an extra box with fans and a custom graphiccard on your desk. (Mainly ment as a solution for gamers)
If you can share a typical file here then maybe someone with an integrated intel gpu can test it out for you :slight_smile:
People requesting ā€œthe best laptopā€ for Rhino need to be clear on what they are looking for. A heavy laptop is a 10 lbs system, 4 - 6 lbs should be considered thin and light since these machines will generally be running a 200 W power supply and you just need a certain amount of mass to handle that kind of power/heat. People complaining of loud fans need to understand that there is either damage to the notebook or you are pushing the system hard and it is a simple equation relating to very small pipes and a requirement to dissipate a bunch of heat. Laptops that stay quite and cool when pushed hard are just throttling the processor or video card performance. When it comes to Quadro vs GeForce (they are both labeled RTX) you just need to decide if certified graphics is a requirement for your application (and you are willing to pay for it) as they both support OpenGL. It doesn’t seem like Rhino does any of the certified graphics driver stuff so if you are trying to go less expensive, GeForce is the way to go as it is generally better performance for the money. That being said you will find better balanced laptops (weight to performance) running Quadro cards.
lol shoulda looked at this thread before I posted ;D still pretty confused though - need to get something I can order online…
I need to be able to run Rhino and Adobe products concurrently, and I’m about to get serious with Grasshopper, so any recommendations? What I’m getting based on what you’re saying is
GeForce cards are good
Lenovo p53 or 73 if I don’t mind the bulk
MSI P65 Creator-1084 15.6" 4K Laptop Intel Core i7-9750H, GeForce RTX 2060, 32GB
ThinkPad P1 Gen 2 Workstation 4K IPS i7-9750H, T2000,32G RAM ?
Dell Precision 75XX…pricey but a workhorse
Asus Zephyrus-M.
What do you guys think of this one/? MSI GL75 9SDK-057 17.3" FHD 120Hz Gaming Laptop, Intel Core i7-9750H, NVIDIA GTX 1660Ti, 16GB, 512GB NVMe SSD, Win 10
FYI I did end up getting that Thinkpad. havent installed any apps on it yet just setting up Win10 to my liking but damn, that machine is sexy af! Mostly runs quiet too
I’ve just got a new laptop with RTX 2060. Mainly going to be using Rhino and Blender. Got a a massive scare finding that Blender didn’t support RTX cards, but does now. Then the much older 1080ti card kept popping up as recommended.
Still have no idea if I would’ve been better off with something like Quadro P3200. I never found any real definitive answer on what kind of card is better for modelling / rendering, or if that is where the dividing line between GeForce and Quadro is.
Curious which laptop is it and how much did you spend on it
Chassis & Display Vortex Series: 15.6" Matte Full HD 144Hz LED Widescreen (1920x1080) + G-Sync
Processor (CPU) IntelĀ® Coreā„¢ i7 Six Core Processor 9750H (2.6GHz, 4.5GHz Turbo)
Memory (RAM) 32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
Graphics Card NVIDIAĀ® GeForceĀ® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectXĀ® 12.1
1st Storage Drive 1TB Samsung 860 QVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR
1st M.2 SSD Drive 512GB IntelĀ® H10 NVMe SSD + 32GB IntelĀ® Optaneā„¢ (upto 2300MB/sR
Memory Card Reader Integrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
Bluetooth & Wireless GIGABIT LAN & WIRELESS INTELĀ® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0
USB/Thunderbolt Options 1 x USB 3.1 PORT (Type C) + 2 x USB 3.0 PORTS + 1 x USB 2.0 PORT
I got the above. My budget was Ā£1500 and this fell inside that. Main thing I’d established was might as well get something with capability for 32GB RAM.
Also considered:
Various HP ZBooks, for i9 processors, creeping quickly up to £2000, All Quadro cards
Razer blade, nicer hardware but price spiralled fast
Other models on PC Specialist, like:
https://www.pcspecialist.co.uk/form-view/recoil-III-17/Recoil-Master/
https://www.pcspecialist.co.uk/notebooks/defianceXS-pro-II-15/
QUickly became apparent I could easily nudge a spec up on many thing, but often to the tune of 3-400 pounds. Not sure if I’d see it - I won’t be gaming much, this will be for work.
Hi all, I run Rhino from R2 and I don’t understand why you look at the highest perf laptop and expensive.If you’re not using raytracing all day you can run Rhino easily on middle price laptop.I 'm used to work on heavy 3dm and for having used geforce and quadro I suggest to forget about quadro cards , way too expensive, geforce consummer cards are very very powerfull nowdays and cheaper.
Don’t believe benchs the difference is not enough that you could see
thanks for that idea. does make sense.Ended up with ThinkPad P1
I do have a similar notebook setup as Jonathan (Dell G5), I wanted a laptop ready to do VR as well. Can’t recommend it though. Heating and noise is really annoying, but its cool to use my VR headset in the Garden. For Rhino, much lesser specs are totally okay, although it also depends on the job…
