Batch Export .dwg
Hi I’m looking to export .dwg’s for every layer in a rhino file. The simple script below works but it writes over the file name with Layer, when what I want is the file to be titled by the Layer. Anything simple I can do to adjust?
Thanks in advance,
Joey
def main():
layers = rs.LayerNames()
if layers:
for layer in layers:
rs.Command(’! _-SelNone’)
rs.ObjectsByLayer(layer, True)
rs.Command(’! _-Export layer _Enter’)
if name == “main” : main()
Something like this perhaps…?
BatchExportDWGByLayer.py (1.7 KB)
Is there a way to export dwg by layers in solids?
This should work if the last-used DWG export scheme supports solids - i.e. 2007 Solids. Run the Rhino command Export first and make sure this scheme is set (you can cancel afterwards). Then run the batch export.
Yes, i figured i had to change the export options before running the script. Thanks for this. I really need to get into python.
