Would it be possible to specify export scheme in "Export" command?
It would be really helpful if there was an option either in the “Export” command or via any API (rhinoscript, RhinoCommon) to export selected objects to DWG via a specific Export Scheme (saved in a file). Is it possible? I couldn’t find it in the command and I couldn’t see any export command in rhinoscriptsyntax.
You need to have first created an export scheme and named it (or use one of the stock schemes). Then you can create a command line export string to run via rs.Command() or even a macro that includes the scheme.
filepath = "C:\Users\YourName\Desktop\TestFile.dxf"
comm_str = '_-Export "{}" _Scheme "2007 Natural" _Enter'.format(filepath)
rs.Command(comm_str, True)
-_Export C:\XXX\XXX.dwg _S 2007 Natural _EnterEnd or similar should do.
Fantastic, thank you very much @Helvetosaur and @gankeyu. That will make things much simpler :slight_smile:
Does it work for other file formats as well? Or do you know if there is any reference for options to this command available somewhere? I couldn’t find anything in the help panel or in the first page of googling “rhino export options”.
Sorry, does it still work on Rhino 8 WIP? It errors “Unknown command: Scheme”
import os
rs.Command('-Export "C:\\Users\\<Username>\\Desktop\\test" Scheme "Default" _Enter')```
Nope - looks like that is pretty broken… @dale ?
For V7, you do need to specify the .dxf extension in the file name… Otherwise it doesn’t know what file format to use.
rs.Command('-Export "C:\\Users\\<Username>\\Desktop\\test.dxf" Scheme "Default" _Enter')
Personally I prefer setting up the file path separately (as in the earlier example) and using raw strings instead of escaped backslashes…
rs.Command(r'-Export "C:\Users\<username>\Desktop\test.dxf" Scheme "Default" _Enter')
Thanks for confirming, hopefully it can be fixed soon.
Yes, the above two lines were just meant to frame the problem. In the full script I’ve added the file extension to the filename. It needs to be dwg unfortunately in autocad you can’t xref dxf files :frowning:
You are right that raw strings simplify windows file paths - I’ll try to use them more often.
import os
file_name = rs.OpenFileName()
# in case user added extension
file_name_without_ext, file_name_with_ext = os.path.splitext(file_name)
file_name = file_name_without_ext + ".dwg"
rs.Command('-Export "{}" Scheme "Default-Copy" _Enter'.format(file_name))
DWG and DXF use the same export settings scheme, so all that is necessary in this case is to change the extension.
Hi, I haven’t checked if this has been addressed yet in the latest Rhino build, but I just wanted to add that it would be really helpful if you could also specify the DWG export scheme settings directly in the script - having these settings in a separate file makes it less portable - being able to specify them directly in the script would mean that all users need is that one python script to correctly share DWGs across the team.
Would it be feasible to add this feature in the near future?
